Installing a New Major Version
Navigation:  Quick Start >
Profiles Backup for SyncBackProV10 and earlier Users
When SyncBackPro is first run it will check to see if it has been installed over an older version, e.g. V12 installed over V11. If so, it makes a backup of the existing profiles and settings of the older version. The purpose of this backup is so that if you decide to uninstall the newer version and re-install the older version, then the older version can restore your old settings and profiles. It is important to note that you must install the latest version of SyncBackPro to be able to restore your settings and profiles. You can download old versions from https://www.2brightsparks.com/downloads-legacy.html
You can choose which folder to make a backup of the profiles and settings in, but it is recommended that you do not and instead use the default (e.g. C:\Users\[username]\Documents\SyncBackProV10 Backup\). The default location is a sub-directory of your users application data folder. After SyncBackPro has made the backup it will open a Windows File Explorer window so you can see which folder it is and the files in it.
The backup files will be automatically deleted by SyncBackPro once a valid serial number is entered and 60 days or more have passed since it was first run. You can manually delete the backup files yourself if you are sure you are not going to revert back to the older version.
For example:
•You are currently using SyncBackPro V11 and decide you want to try V12.
•You install SyncBackPro V12. Note that you do not uninstall V11 first.
•When V12 is first run it will make a backup of your V11 profiles.
•You try V12 and later decide you want to return to using V11, so you uninstall V12 and then install V11.
•When you first run V11 it will restore the profiles you had when you were using V11 previously.
32-bit and 64-bit
64-bit versions of SyncBackPro and SyncBackSE were introduced in SyncBackPro/SE V8 (June 2017). Unless you are using an old 32-bit version of Windows, you should install the 64-bit version. There is no 32-bit version of Windows 11 or server versions of Windows.
You should not have 32-bit and 64-bit versions installed at the same time. To switch from one version to another (e.g. 32-bit to 64-bit) you should export your profiles, uninstall the old version, install the new version and then import your profiles.
Be aware that there are differences between the 32-bit and 64-bit versions due to how Windows itself acts differently.
