<< Click to Display Table of Contents >> Navigation: »No topics above this level« UndeleteOnClick |
A Guide to Using UndeleteOnClick
UndeleteOnClick is a very simple to use file undelete utility for Microsoft Windows 7 SP1 (Windows 2008 R2) and newer (32-bit and 64-bit).
Any type of file can be undeleted / unerased, including NTFS compressed & NTFS encrypted files.
Note that you will not be able to retrieve files that have been deleted with DeleteOnClick using UndeleteOnClick. |
UndeleteOnClick can undelete files from any NTFS or FAT (exFAT, FAT 12, 16, 32) drives, including: hard drives (internal and external); USB Keys; etc.
Program Information
File Name |
DeleteOnClick_Setup.exe |
License |
Freeware |
Benefits |
Recover compressed (NTFS based) files. |
Recover encrypted files on NTFS drives. |
Recover alternate data streams (ADS). |
Restores using the correct creation & modification date & times. |
Very fast MFT and FAT scanning algorithm, fast file undelete. |
Undelete files on any valid logical drive visible by Windows. |
Fully Unicode enabled so filenames in any language can be undeleted. |
Fits on a small capacity USB key. |
Gives chances of file recovery. |
UndeleteOnClick is available from 2BrightSparks.
