<< Click to Display Table of Contents >> Navigation: FindOnClick > FindOnClick For Advanced Users > Scripting > Functions > Strings |
function SameText(String1, String2);
String1: The string to compare with String2.
String2: The string to compare with String1.
Return value: Returns TRUE if string1 and string2 are the same (case insensitive).
function SameStr(String1, String2);
Return value: Returns TRUE if string1 and string2 are the same (case sensitive).
<%SBCOPYRIGHT%>
