<< Click to Display Table of Contents >> Navigation: FindOnClick > FindOnClick For Advanced Users > Scripting > Functions > Search Settings |
procedure AbortSearch;
Call this procedure to abort the search. This can be called at any point in the script. However, FindOnClick may not be able to abort immediately.
function SS_SearchPaths;
Return value: The total number of paths being searched. Get the path using SS_SearchPath.
function SS_SearchPath(Index);
Index: The search path to retrieve, with the first being zero (0). Use SS_SearchPaths to get the total number of paths.
Return value: The search path.
function SS_SearchPathsAreRegEx;
Return value: TRUE if the search paths are regular expressions.
function SS_RegExDrives;
Return value: If the search paths are regular expressions, then this returns the drives that are to be searched, e.g. 'CDF' means the drives C:, D: and F: are going to be searched. If empty, then all drives are searched (which includes A: and B: if SS_DrivesAB is TRUE).
function SS_FilenameFilters;
Return value: The total number of filenames filters. Get the filters using SS_FilenameFilter.
function SS_FilenameFilter(Index);
Index: The filename filter to retrieve, with the first being zero (0). Use SS_FilenameFilters to get the total number of filters.
Return value: The filename filter.
function SS_PathFilters;
Return value: The total number of path filters. Get the filters using SS_PathFilter.
function SS_PathFilter(Index);
Index: The path filter to retrieve, with the first being zero (0). Use SS_PathFilters to get the total number of filters.
Return value: The path filter.
function SS_SlowSearch;
Return value: Returns TRUE if a slow search is being performed.
function SS_DrivesAB;
Return value: Returns TRUE if drives A: and B: are to be included in the drives list. This is only relevant if SS_RegExDrives is empty and regular expression searching is being used.
function SS_HaveMinSize;
Return value: Returns TRUE if files must have a minimum size.
function SS_MinSize;
Return value: Returns the minimum size of a file to include. Ignore this value unless SS_HaveMinSize is TRUE.
function SS_HaveMaxSize;
Return value: Returns TRUE if files must have a maximum size
function SS_MaxSize;
Return value: Returns the maximum size of a file to include. Ignore this value unless SS_HaveMaxSize is TRUE.
function SS_HaveMinModDate;
Return value: Returns TRUE if files must have a minimum last modification date & time.
function SS_MinModDate;
Return value: Returns the minimum last modification date & time of a file to include. Ignore this value unless SS_HaveMinModDate is TRUE.
function SS_HaveMaxModDate;
Return value: Returns TRUE if files must have a maximum last modification date & time
function SS_MaxModDate;
Return value: Returns the maximum last modification date & time of a file to include. Ignore this value unless SS_HaveMaxModDate is TRUE.
function SS_HaveMinCreateDate;
Return value: Returns TRUE if files must have a minimum creation date & time.
function SS_MinCreateDate;
Return value: Returns the minimum creation date & time of a file to include. Ignore this value unless SS_HaveMinCreateDate is TRUE.
function SS_HaveMaxCreateDate;
Return value: Returns TRUE if files must have a maximum creation date & time
function SS_MaxCreateDate;
Return value: Returns the maximum creation date & time of a file to include. Ignore this value unless SS_HaveMaxCreateDate is TRUE.
function SS_IncludeExtensions;
Return value: The total number of filename extensions being included in the search results. Get the path using SS_IncludeExtension.
function SS_IncludeExtension(Index);
Index: The filename extensions to retrieve, with the first being zero (0). Use SS_IncludeExtensions to get the total number of filename extensions.
Return value: The filename extension.
function SS_ExcludeExtensions;
Return value: The total number of filename extensions being excluded from the search results. Get the path using SS_ExcludeExtension.
function SS_ExcludeExtension(Index);
Index: The filename extensions to retrieve, with the first being zero (0). Use SS_ExcludeExtensions to get the total number of filename extensions.
function SS_HashType;
Return value: The type of hashing being used, e.g. EHT_MD5.
function SS_DuplicatesOnly;
Return value: TRUE if only duplicate files are being displayed.
function SS_Attrs;
Return value: The file attributes being filtered See SS_AttrsChoice to see how this value is being used.
function SS_AttrsChoice;
Return value: How the file attributes (see SS_Attrs) are being filtered, e.g. EAttrs_Exact
function SS_SearchString;
Return value: If the contents of files are being searched then this is the string being searched for.
function SS_SearchStringIsRegEx;
Return value: TRUE if SS_SearchString is a regular expression.
function SS_SearchStringDeepSearch;
Return value: TRUE if a deep search (using SS_SearchString) is being performed.
function SS_SearchStringCaseSensitive;
Return value: TRUE if SS_SearchString is case sensitive.
function SS_GetVersion;
Return value: TRUE if file version numbers are being retrieved.
function SS_GetMP3;
Return value: TRUE if MP3 data is being retrieved.
function SS_IgnoreFolders;
Return value: TRUE if folders are being ignored.
function SS_IgnoreFiles;
Return value: TRUE if files are being ignored.
<%SBCOPYRIGHT%>
