<< Click to Display Table of Contents >> Navigation: FindOnClick > Using FindOnClick > FindOnClick The Right Click Menu |
Using FindOnClick: The Right Click Menu
Select a file from the list of search results and click the right mouse button to display a special menu that allows fast access to many of FindOnClick's features:
Press and hold the right mouse button for half second on a selected file in the search results window to display a Windows File Explorer context menu:
